Author Topic: Specs for each Voltage on the Pie  (Read 95351 times)
Re: Specs for each Voltage on the Pie
« Reply #15 on: July 16, 2010, 11:22:59 PM »
I'm still wondering though - why is the LVC is set to 35V in a 36V system?...
The LVC is designed for lithium packs.
You said that one SLA had lost much capacity.
Ok
If you are using 3 SLA.  35v/3 = 11.6v.  If one battery is not doing as good as another in series it could be down a volt.  This pack discharged at 35v with a runt SLA would be very bad for EV applications.
Do a test.  Hook up your multimeter to the runt SLA and fully discharge your pack on a ride to LVC.  Now you will see that the failing SLA voltage isn't performing up to scratch, probably dropping lower than 8v and shunting everything from the other packs.
Your LVC is hitting in the blink of an eye.
When I charge a battery I can watch the volts go up slow till it is charged and almost see the highest volts on the meter up until float charge mode cuts the volts.  When the battery is full, if I reinitialize bulk charge state by unplugging the charger and replugging the charger back in the volts will go up so fast I do not even see the highest volts on the meter.  It only gets to 14.8v and stops instead of 15v.  If I leave the charger on over night and do it again I am lucky to get enough time to see the volts go up to 14.5v  This is really reaching 15v but my digital LCD display is not fast enough to catch it.
This could be happening to you when you twist the throttle and the volts go down so fast the LCD screen isnt able to show you you this.
To put a lot of energy and power into a hub motor with out overheating the controller or power cables the controller breaks up the power into little packets, When you throttle the controller expands and narrows the width of these packets to your throttle use, this is called pulse width modulation (PWM). PWM also makes speed control very efficient.
When the batteries obtain so much resistance, lack of current on a decent load delivered by PWM may start to pulse the the rail voltages down in the controller.  So what you may see at the terminals maybe also different in the caps at the controller. You would need a good oscilloscope and probe in the controller to see this anomaly in action.  The spikes and dips in voltages are very fast.
I also think there is an LCC and HCC in the controller too. Low current cut off and high current cut off.  Not too much is documented with this but from memory, with the older controllers, there was a whisper of info about this some time ago.
Maybe try setting it at 24v to see if there is any difference but I feel you wont see much with the runt SLA's in the pack.  Be carefull because 24v LVC will finish your SLA's and you could be heading towards controller failure if you push things too far..
« Last Edit: July 16, 2010, 11:57:19 PM by 317537 »
Offline Magneto81
« Reply #16 on: July 23, 2010, 12:13:39 AM »
So how can I change the LVC because 35V LVC is rediculous for Lead Acid.
« Reply #17 on: July 23, 2010, 12:19:42 AM »
Just use the interface cable and software to reset the controller back to 24V instead of 36V.
Offline Magneto81
« Reply #18 on: July 26, 2010, 01:30:22 AM »
I still want the information though.
In the meantime, I finally have my bike set up with 48V 12AH batteries and it's working great! I was getting 38km/h today and that's with the bike set at via the software to 11A continuous. (11*48V=528W, although the highest watt usage was more like 450 according to my cycle analyst.) I think that's pretty great! The acceleration isn't bad at that level either - although it needed some help up a couple of steepish hills.
Luckily - no voltage slump made the machine fail, so that was great!
I'll let you know if/when I find out the LVC for 48V.
« Reply #19 on: July 26, 2010, 01:45:53 AM »
Cheers.  Good move to reprogram the hub at 11A like that.  Changes a lot of problems you may incur in the future. You could do a little higher,  15 amps max once your SLA's are cycled a little, if you're not doing so much range it's not so bad.  The voltage slump when your SLA's are low can do the damage to an individual battery, especially if your current draw is too high.
38kms is pretty good for a 48v 12ah pack.  I think LVC on the 48v GM pack is around 34v  The cells can discharge to 2.4~2.6v and there are 13 of them in the GM packs. 33.8v  Even this is too low for four SLA's.
You may want to make your own warning lamp that shuts off at 43v.  Or keep ya eyes on the CA to measure your full charge.
With SLA's 45v is pedal assist time 43v is turn off the bike and ride home.
« Last Edit: July 26, 2010, 02:00:12 AM by 317537 »
