Author Topic: 18 wheel Magic Pie and twist throttle  (Read 208845 times)
Re: 18 wheel Magic Pie and twist throttle
« Reply #45 on: May 08, 2010, 11:31:05 AM »
Or no fuse at all. Seriously.
Do not ride bike unless you.
Make a very good connection. Be sure no thing will interrupt the power connection.  Never.
Tape your plugs together.  Make good tight wheel nuts and throttle.  Check brakes, all connections.  Cord leads are out of the way and tied to frame.
When it is all good.
Ride it and enjoy.
« Last Edit: May 08, 2010, 11:33:19 AM by 317537 »
« Reply #46 on: May 08, 2010, 11:37:54 AM »
Do run the motor when not tightened the nuts properly
Leslie, I think you meant to say  DON'T ;)
It won't make any difference to the current whether you use a 36 or 48 Volt battery, the maximum current limit of the controller will still be the same.
Mine appears to be limited to ~20 Amps, but some are set at ~30Amps. 21.23Amps is the highest reading I have obtained on my Turnigy Watt Meter, and that was during some steep hill off road use.
« Reply #47 on: May 08, 2010, 12:04:46 PM »
Fixed.
Its just one of the early videos circulating around had one man show us how his golden motor worked running it full RPM holding it with his fingers..
Offline Valy
« Reply #48 on: May 12, 2010, 07:21:03 PM »
some electric work. in a rainy day  ;D
« Last Edit: May 12, 2010, 07:33:18 PM by valy »
Offline Valy
« Reply #49 on: May 12, 2010, 07:23:20 PM »
more cables
Offline Valy
« Reply #50 on: May 12, 2010, 07:25:49 PM »
2 more
Offline Valy
« Reply #51 on: May 17, 2010, 07:17:16 PM »
hello today I recive my tire
Offline Valy
« Reply #52 on: May 17, 2010, 07:29:33 PM »
some problem with valve.
 I must to drill anoder hole in one side of the rim . and cover the original hole with tape
« Last Edit: May 17, 2010, 09:01:22 PM by valy »
Offline Valy
« Reply #53 on: May 17, 2010, 07:33:54 PM »
naw it is ok.
Offline Valy
« Reply #54 on: May 17, 2010, 07:37:18 PM »
naw the kids have fun ;D they drove all day
and the tube have a little hole I must too fix it(new tube.with small  small hole)
« Last Edit: May 17, 2010, 08:46:53 PM by valy »
Offline Valy
« Reply #55 on: May 17, 2010, 08:57:33 PM »
in after noon I drive the bike in the tawn 20 km and  I I had still 24,5 volt when I come homme
I have only 24 volt because for my  son is too mutch 36 volt. hi have only 8 year and hi it is skeard :o
I will put some video but naw I have problem with video codec >:(
GOLDEN MOTOR 18 INCH CASTED WHEEL IT IS VERY ,VERY ,VERY ....SILENT . in very bigg hill make little sound in a full throttle. but with pedal help is no sound  ;D  naw all my kids want one electric bike : :o my son is very happy  8) ;D
« Last Edit: May 17, 2010, 09:16:40 PM by valy »
Offline Hardcore
« Reply #56 on: May 17, 2010, 09:05:05 PM »
Try using adobe premiere cs4 or cs5, it support almost everything. Except foreign codes. Or try decoders on google.
Well hope to see a vid of 24 v :D
Offline Valy
« Reply #57 on: May 17, 2010, 09:23:39 PM »
I have a new canon legria fs200  with 3cd driver but in my computer is work 3-4 sec stop 2-3sec start 3-4sec stop again etc..
.I will try your advice. to see if it is work .thank you.
Offline Valy
« Reply #58 on: July 23, 2010, 09:42:44 AM »
hello my son bike with  lifepo4 battery
Offline Valy
« Reply #59 on: July 23, 2010, 11:17:38 PM »
« Last Edit: July 02, 2017, 02:52:10 PM by Bikemad »
