Author Topic: 18 wheel Magic Pie and twist throttle  (Read 208846 times)
Re: 18 wheel Magic Pie and twist throttle
« Reply #30 on: May 02, 2010, 12:56:05 AM »
Shweeet curves.
I'm just starting to get a good bead on a stick welder.
This is something Id like to do myself.
« Reply #31 on: May 02, 2010, 01:25:57 AM »
haw look naw . is ready for electric kit  .  but is not coming it is over 13 days.  ???
All you need to finish off the look is some great fairings.
http://www.morcmtb.org/forums/showthread.php?t=29713
This guys says hes selling them for $399 each.
« Reply #32 on: May 02, 2010, 01:52:18 AM »
The only criticism I could give is that pointed weapon thing near the cranks could be dangerous in an accident or to poor unsuspecting animals that may run in there, going at 45kph, ouch.
Offline Valy
« Reply #33 on: May 03, 2010, 05:01:12 PM »
today the magic is here   .mutch disepoiment  >:(       some pictures
« Last Edit: May 03, 2010, 05:46:43 PM by valy »
Offline Valy
« Reply #34 on: May 03, 2010, 05:03:37 PM »
more picture
 I don't understand what is the problem with the disc  is it for  wrong side ??? is coming in side where the chain  supose to be. ???You guys can you help me please  ???
« Last Edit: May 03, 2010, 10:33:40 PM by valy »
Offline Valy
« Reply #35 on: May 03, 2010, 05:05:37 PM »
more pictures where you can see 18 wheel inch golden motor is inside the 17 inch motorcycle rim . Is it normal  ??? ??? ??? ??? ??? ??? ??? ??? ???.golden wheel look like 12 inch ;D :'(
« Last Edit: May 03, 2010, 10:36:23 PM by valy »
Offline Valy
« Reply #36 on: May 03, 2010, 05:20:26 PM »
I have many questions  ???  .
 This wheel is not what it is in the Golden Motor picture.   (see the site)
 It is better if Golden Motor put pictures of each size of wheel(16,18,20.cast) because they look different,and to write under the pictures . which tire can be fitted in each one of them.
all the parts came with scraches (bad delivery) or....Golden Motors fault.I >:( >:( >:(t also came without instructions . >:( :-\
The cable for the wheel have one cut it's not mutch but  I don't like it. (Golden Motor is not good in  packing. Next time put some cover on the cables ,and something   on the wheel .(plastic cover or something)  comming more.
« Last Edit: May 03, 2010, 10:23:36 PM by valy »
« Reply #37 on: May 03, 2010, 11:35:10 PM »
Valy, the sizing of motorcycle and pushbike wheels is done differently.
On a motorcycle with a 18" rim, the 18" relates to the tyre bead diameter (the inner diameter of the tyre), but on a push bike it relates to the overall tyre size (the outer diameter of the tyre).
As the Magic Pie is intended for pushbikes, it is therefore measured as per all other pushbike wheels.
You have been supplied with a screw on disc instead of the bolt on one which the Magic Pie requires.  It looks like someone has made a mistake with the packing and accidentally supplied you with the wrong brake disc! ::)
« Last Edit: May 03, 2010, 11:38:19 PM by Bikemad »
Offline Valy
« Reply #38 on: May 04, 2010, 05:41:29 PM »
Thank you again  Alan you are the best  :) answer promt all the time.
how  do they think too send a disc screewd to a (  rear wheel   ) and with hols for disc in a oder side
today I have been in a bike shop and I ask abaout tire and they told me don't have. and don't hire abaut 18 inch in a bike wheel. where I kan find tire for this wheel I whish to have 2.75 or 3.50 if exist for this wheel
 (in europe)
« Reply #39 on: May 04, 2010, 07:40:42 PM »
Nice kit.
Looks awesome with no spokes.  Very strong.
Shame about the disc though.
Offline Valy
« Reply #40 on: May 05, 2010, 07:08:59 PM »
hello .
today I will try to start the motor on 24 volt bicause I m scared to burn the controller.
 this is the first time when I do this electric stuff . if this works I will put a video online.
WISH ME LUCK !!!  ;D
Offline Valy
« Reply #41 on: May 05, 2010, 09:12:41 PM »
hello
 my motor it is work .
but when I move the cables the motor start to bip 3 time and stop.
  maibe the conection is bad or cable with problem they are to thin  very easi to break. I will buy anoder battery to try on 36 volt.
the speed is very slow in 24 volt ,
 what is with red buton for the throttle I press on or off and  motor is work anyway .  for what it is  ???
« Reply #42 on: May 06, 2010, 01:31:35 AM »
Valy, three beeps indicates a throttle fault, check the throttle wires carefully at the connectors.
Check this post for more details
The red button is not connected to anything, but it can be used to turn your lights on and off etc. as long as the current is relatively low, usually used with the LED lights.
You should have two spare wires (a brown and a yellow one) coming from the throttle cable, these are wired to this red switch on the throttle control unit.
Just tested it with 36V and 48V and I will newer ride it with 36V again! Sure it is just 10km/h diffrence in top speed, but everything else is awsome!
Offline Valy
« Reply #43 on: May 07, 2010, 07:03:01 PM »
hello
  I wish to put a fuse on the + cable but I don't  know how many amps to put if you kan help me  ??? for 36 volt 30amp battery  or 48 volt 30amp battery .
 my light in throttle is full in 36 volt .this  is a 36 volt throttle ??? I don't find tire bigger then 18,2 inch
 sombody know if exist ???18 3,50 or18, 4inch.
« Last Edit: May 07, 2010, 07:40:08 PM by valy »
« Reply #44 on: May 08, 2010, 11:17:01 AM »
hello
Thats been a well discussed question.
You have a BMS that should limit the current just above what the Pie uses.  If that doesnt work as expected you want 35 amps.
But what makes all this a useless waste of font.
Read on.
There is still is the warning "Important Note: While using regenerative braking, DO NOT turn off the battery". as per GM PDF installation Guide  If the fuse blows while braking the controller could fail..
Use a 45, 50 amp fuse just to be safe .
Be gentle Valy.
Set it up.  Do not run the motor when not tightened the nuts properly.
« Last Edit: May 08, 2010, 11:59:24 AM by 317537 »
