Author Topic: 10KW BLDC Motor for Electric Car  (Read 165285 times)
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
« on: March 22, 2010, 05:24:36 AM »
Offline GM Brazil
Re: 10KW BLDC Motor for Electric Car
« Reply #1 on: March 22, 2010, 07:21:14 AM »
Thanks Yao!
I was going to question you about 10kW motors! I have a client for that! Do you have them to buy one sample in my next order?  I will tell the client that we have this available and see if he wants one for testing!
How much heat we need to dissipate with the water cooling?
Offline evo
« Reply #2 on: April 08, 2010, 02:48:54 PM »
Dear Yao,
I like your water cooled engine!
Do you have any further information/ tech. specs?
At the first moment it looked to me like a HPM 5000B with two double Amp limits and more weight....and more length?
I'm also a little  bit confused about the power 5 - 10 kW?
But hopefully I will understand the benefit better after reading your answer :)
What about the controller?
Do you know  a price for such a unit already?
Anyway it looks great and if also the controller is water cooled it will be a perfect combination!
Find the future asap,
Kind Regard
EVO
Offline Galileu
« Reply #3 on: February 01, 2011, 10:08:54 AM »
I am very interested in your BLDC motors. I am working on a project for the conversion of a light 4x4 off-road vehicle and these motors seem to be worthy of consideration.
Best regards,
Jose B. Almeida
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
« Reply #4 on: May 06, 2011, 03:03:10 AM »
New version of 10KW BLDC Motors available now. Check http://www.goldenmotor.com
Offline Batiskaf
« Reply #5 on: October 19, 2011, 09:18:06 PM »
I want to buy 10KW BLDC Motor for my car. You can specify the amount of the invoice and other documents for the goods delivery to Ukraine will not exceed $ 200 (USA)?
Re: Customs declaration amounts
« Reply #6 on: October 20, 2011, 12:20:51 AM »
That question should really be directed to the sales department at GM in China rather than the forum.
Send an email to sales@goldenmotor.com and see what they say.
« Reply #7 on: October 20, 2011, 03:06:26 AM »
If I am correct, you are asking someone to do something illegal in a public forum?
If you are trying to save money on import tax how much could the tax be? I don't think its worth it in my opinion and quite often customs is wise to this and things get messy at that point. I know I declare everything at actual sale value as I like to insure it and keep things legal in case of issues.
Offline Batiskaf
« Reply #8 on: October 20, 2011, 09:02:19 PM »
You see, if the price is right, I'll give 40% tax. Also in the calculation of the tax includes delivery. It's funny, but such laws.
Offline Batiskaf
« Reply #9 on: October 28, 2011, 08:48:11 PM »
What controller do I need to 10KW BLDC Motor?
I want to buy HPC500A . My choice is correct?
« Last Edit: October 28, 2011, 11:25:30 PM by spellchecker »
Offline Batiskaf
Offline Henry Chang
« Reply #11 on: March 14, 2012, 01:42:51 PM »
HPM5000B Rated Power: 3 KW-7.5 KW
10 KW Brushless Motor Power: 10 KW-20 KW
When the largest power refers to the peak power, power supply can achieve short time to the most high power, when the motor power can reach peak when climbing.
Water cooling system controller demand is higher, to fully eliminate leak, off the water situation occur. However with aluminum to come loose hot effect is good, and convenient security.
Offline Praveen
« Reply #12 on: June 16, 2012, 03:48:04 AM »
Hi does anyone know the flow rate with which the motor has to be cooled with radiator ? Because I have a radiator in my vehicle so I thought whether I could fit this radiator to cooling the motor.Any idea how much heat the motor develops ?
Offline Tokio69
« Reply #13 on: May 14, 2013, 03:41:24 PM »
I also want to know, if I use a liquid colled motor, do I need a separate pump to circulate the liquid or does the motor does that already?
Offline Rusina
« Reply #14 on: June 16, 2017, 04:18:08 PM »
Hello,
I can assure you that an external pump is needed to cool the GM engines for this type of cooling.
