Author Topic: R1 resistor - 36V 250W Brushless Standard Controller  (Read 25938 times)
Offline barmy
« on: March 17, 2010, 07:58:07 AM »
Hi
unfortunately I cooked my 36V 250w standard brushless controller I bought last year...  :o
I opened it up and from the first look it's only the first ceramic resistor "R1" that is burned  :( ..
unfortunately I cannot read the specs because it's burned!
Can someone tell me please the specs of that resistor??? or schematics?
it would be very easy to replace and worth a try!
Please help me!
Thanks alot
Mike
Re: R1 resistor - 36V 250W Brushless Standard Controller
« Reply #1 on: March 17, 2010, 10:42:13 AM »
Can you post some specs pics?
Usually those power resistors are in the 150/350 ohm range to take the edge off the the high voltage of the pack to the logic and fet driver regulators.
They supply either an LM317t or a LM7812 and LM7805 and take the voltage down by 10v (150 ohm) or so for a 36v controller and (350 ohm) 22v or so 350ohm for 48v.
The output needs to achieve 60ma.
Use at least 3 watt resistors.  The load is around 500ohm, but check the load to see if it is something else causing this resistor blow.  500 ohms is a good ball park figure for testing the load for regulation.
Offline barmy
« Reply #2 on: March 17, 2010, 03:39:05 PM »
thanks alot for your reply!
helps me alot!
i will post a pic as soon as I'm back home...
Thanks!
