Author Topic: -- Solonoid or relay to start the Battery /  (Read 26058 times)
Offline diverdon
« on: December 16, 2009, 12:27:53 PM »
       I have been working on the motor wirirng setup
  For the motor .. Wiring in the "Watts Up" Guage to the harness.. Every Time I put the wires together to hook up the motor
       I geta sorta spark in the plug........ like I said a solinoud might be the woy to go .Thanks , Don J.
Re: -- Solonoid or relay to start the Battery /
« Reply #1 on: December 16, 2009, 01:10:10 PM »
People at the sphere recommend a pre-charge bypass resistor allowing some current slowly through to the controller caps before you switch
I just use one of these. .
 Each pole allows 240v 15 amps so I use both centre poles to battery and throw to the controller and on the opposite throw I connect the battery so when I switch off it connects to the charger plug. This has it has never failed me
If I look into the switch really close in the dark I only notice the smallest of sparks. My controller is 40 AMPS.
