Author Topic: 42V on 36V system  (Read 97343 times)
Offline erdurbin
    • not so Common sense
42V on 36V system
« on: September 05, 2007, 08:04:40 PM »
This was briefly mentioned, but no one ever really got back to it.
I have been running an extra 6V 12ah brick in series to my 3x12v 12ah pack.
I really like the higher top end and the torque seems much better. I have to be careful when starting out and only go about 1/4 to 1/2 throttle until I get around 10mph. Otherwise, the amps jump over 30 and is really unnecessary. I am not trying to drag race my bike, I just want a little more help. With this setup, I can achieve easily 17-20mph up a basic hill. Before, I was getting around 12-16mph.
When my pack is fully charged, it is around 46-47 volts. If the amps jump to around 30, I have sometimes seen around a 7-10 volt drop. This is why I try to not give full throttle if I can help it unless I am up to speed.
I will post pics later of my pack. I use a watts up meter to monitor my voltage and amps while riding.
Has anyone else tried this? It does not heat up anything more than my 36V system seems to.
This is just something I have tried temporarily until I get my LiFePO4 pack from Skeuter.
Offline myelectricbike
Re: 42V on 36V system
« Reply #1 on: September 05, 2007, 08:50:33 PM »
First the applied voltage is being supplied to the motor using PWM (Pulse Width Modulation). Consequently you are applying a constant voltage and current in pulses whose width represent watts. Consequently when you are feeding an excess number of watts to the motor above its rated wattage and the inductive resistance that is in proportion to the actual RPM is exceeded then you get a current spike and a voltage dip due to insufficient inductive resistance to limit current.
(I think that's right but honestly I have not had breakfast or lunch and was working on another project very late last night so its hard for me to actually no what I'm writing until I read it again.)  ;D
« Last Edit: September 06, 2007, 03:33:10 AM by myelectricbike »
Offline erdurbin
« Reply #2 on: September 05, 2007, 11:26:04 PM »
It was only an experiment. I actually get better long term results with just 36 volts. I get a quick turbo boost for about a mile and then my controller starts cutting out from the voltage sag. Not sure what causes it, but I took my 6 volt off today after it kept cutting out so soon. However, it is pretty nice for a mile. Maybe if I used a dpdt switch as mentioned in another post I could only use it when I wanted to.
« Reply #3 on: September 05, 2007, 11:37:08 PM »
My experiment with a 12 volt instead of a 6 volt resulted in shorted phase power leads three times in a row but after the last "upgrade" in wiring I used the 48 volt controller and only had cut outs just before making it back home. I have not upgraded the windings themselves yet by adding a couple of extra strands but that might resolve the problem. I am hesitant to do it because of the polyimide cost. Instead I go very gently on the throttle and jam it only when needed. A motor specifically designed for 48 volts would solve the problem but if I can have 48 volts then I'll probably hold out for 72. ;D
Offline cadstarsucks
« Reply #4 on: September 06, 2007, 02:05:38 AM »
Inductive impedance.  Resistance (R) on the order of 0.5 ohm and inductive impedance (XL) for inductance of perhaps around 1H ( XL=2(PI)FL )
Inductive impedance is called the imaginary portion since it does not actually dissipate power but only stores it.  The resultant impedance is the square root of the sum of the squares or SQRT(0.5^2+XL^2) at an angle of SIN(XL/R).
In an AC circuit the angle of the impedance has to be included in the current calculation as it will not be in phase with the voltage the way it would be in a resistor.
In an AC motor, the instantaneous current is a bit more complicated since you have the angle and magnitude of the CEMF to remove from the voltage before you can procede to calculate the power lost in the windings.
I had been trying to keep things simple for you ...
Back to the simplified version:  Motor CEMF is directly proportional to motor RPM.
From the HBS-36 performance curve at no load we have 308RPM and at full load we have 216RPM.  from the ratio of these two numbers we can calculate the amount of voltage developed on the winding resistance for that change in current at the supplied 36V:
winding voltage = 36V - 36V x 216/308 = 10.75V
The no load and full load currents are 1.19A and 20.46A, respectively.  From the difference between these we can calculate the rotor resistance:
rotor resistance = V/(Ifl-Inl) = 10.75/(20.46-1.19) = 0.56 ohms
Dan
« Reply #5 on: September 06, 2007, 02:36:49 AM »
Okay, much better. The way to keep things simple is to present one variable at a time, explain it concisely and fully in ordinary terms as you have done here and then move on to the next part of the equation.
It really helps me to think of myself as writing a summary as the way to keep the thing simple and focused. If you do this then even a newbie with no electrical or electronics background who may not understand even the simplest explanation can read and re-read what you have written over time and eventually end up with a complete comprehension using no more than your simple explanation to anchor everything else.
Now on to why 48 volts (or 42 volts under this topic) might be causing phase lead wire insulation to melt,  the controller to cut out or the current to jump while the voltage dips when full throttle is applied to an HBS-36 hub motor.
Good job!  ;D  :P
« Last Edit: September 06, 2007, 02:51:20 AM by myelectricbike »
Offline mustangman
« Reply #6 on: September 06, 2007, 07:01:53 AM »
   Thanks You Dan, I really understood that formula and the concepts. I like things broke down in simple terms for you can teach me some of your electrical knowlege. I can say now that this forum is improving.
« Reply #7 on: September 06, 2007, 10:39:42 AM »
Okay, now in an attempt to address the OP's question, what value is the winding voltage when we apply 42 volts (supply voltage)? And how about the no load and full load currents? What happens to them? Also, what happens to the motor resistance value, does it remain the same when we apply 42 volts to the HBS-36 hub motor?
HBS-36 Design Criteria
MotorCurrentWinding SupplyRPM
ResistanceNo LoadFull LoadVoltageVoltageNo LoadFull Load
RInlIflVwVs
0.5580014921.18920.4610.7532467536308216
ImpedenceInductive MotorInductiveAngular Velocity
AngleImpedenceResistanceReactanceRadiansFrequencyHenries
XL/R(R2+XL2).5RXL2nfL
4504.0634462513.2741850.5580014922513.2741236.2831853074001
4391.4618592450.4423330.5580014922450.442276.2831853073901
4278.8602732387.6104820.5580014922387.6104176.2831853073801
4166.2586872324.7786310.5580014922324.7785646.2831853073701
4053.6571012261.9467790.5580014922261.9467116.2831853073601
3941.0555152199.1149280.5580014922199.1148586.2831853073501
3828.4539292136.2830770.5580014922136.2830046.2831853073401
3715.8523432073.4512260.5580014922073.4511516.2831853073301
3603.2507562010.6193760.5580014922010.6192986.2831853073201
3490.649171947.7875250.5580014921947.7874456.2831853073101
3378.0475841884.9556750.5580014921884.9555926.2831853073001
3265.4459981822.1238250.5580014921822.1237396.2831853072901
3152.8444121759.2919750.5580014921759.2918866.2831853072801
3040.2428261696.4601250.5580014921696.4600336.2831853072701
2927.641241633.6282750.5580014921633.628186.2831853072601
2815.0396531570.7964260.5580014921570.7963276.2831853072501
2702.4380671507.9645770.5580014921507.9644746.2831853072401
2589.8364811445.1327280.5580014921445.1326216.2831853072301
2477.2348951382.300880.5580014921382.3007686.2831853072201
2364.6333091319.4690320.5580014921319.4689156.2831853072101
2252.0317231256.6371850.5580014921256.6370616.2831853072001
2139.4301371193.8053390.5580014921193.8052086.2831853071901
2026.828551130.9734930.5580014921130.9733556.2831853071801
1914.2269641068.1416480.5580014921068.1415026.2831853071701
1801.6253781005.3098040.5580014921005.3096496.2831853071601
1689.023792942.47796130.558001492942.47779616.2831853071501
1576.422206879.646120.558001492879.6459436.2831853071401
1463.82062816.81428050.558001492816.81408996.2831853071301
1351.219034753.98244330.558001492753.98223696.2831853071201
1238.617448691.1506090.558001492691.15038386.2831853071101
1126.015861628.31877850.558001492628.31853076.2831853071001
1013.414275565.4869530.558001492565.48667766.283185307901
900.8126891502.65513430.558001492502.65482466.283185307801
788.211103439.82332550.558001492439.82297156.283185307701
675.6095168376.99153140.558001492376.99111846.283185307601
563.0079307314.15976090.558001492314.15926546.283185307501
450.4063446251.32803170.558001492251.32741236.283185307401
337.8047584188.49638510.558001492188.49555926.283185307301
225.2031723125.6649450.558001492125.66370616.283185307201
112.601586162.834330790.55800149262.831853076.283185307101
00.5580014920.55800149206.28318530701
« Last Edit: September 06, 2007, 11:31:33 AM by myelectricbike »
« Reply #8 on: September 06, 2007, 12:48:00 PM »
Good job!  ;D  :P
The current in an inductor is:
dI=VdT/L
The change in current equals the voltage times the change in time divided by the inductance.  Those with calculus will recognize the little "d" as the notation for the derivative.
This relationship holds true until the inductor saturates.  The inductor saturates when it's core can hold no more magnetic flux, and when this happens the inductance drops to zero.
The motor current is driven by the motor voltage and impeded by the CEMF the series resistance of the winding and the series inductance of the winding.  When the motor core saturates the inductance goes to zero and the motor current is is only limited by the motor resistance, the battery resistance, the wire resistance, and the CEMF so the current skyrockets melting the wires and pulls down the battery voltage through it's resistance.
Dan
Offline pdonahue
« Reply #9 on: September 06, 2007, 01:03:04 PM »
What size (Ah) are your batteries?  I'm running 48V 10Ah sla and the voltage drop is normally around 5-7 volts, but I've never noticed how high it peaks during startup.
As for heating up, for the first week that I was running the 48V setup I was checking all the wires frequently because I was fully expecting a meltdown at some point.  The only one that seemed to get even warm was the 18AWG wire coming from my battery (it was an old computer power extension cord that already had the right plug on it).  It would get warm to the touch while riding and that made me a little nervous.  I replaced it with a 14AWG power cord and now there is no noticable temperature increase.
Pete
« Reply #10 on: September 06, 2007, 01:59:05 PM »
Umm....I was just taking a pot shot at the inductance... reality is a bit more complicated as it is three phase.  That is, however the first time I have seen the actual drive frequencies...interesting that they go to the 400Hz aircraft power frequency...
Dan
« Reply #11 on: September 06, 2007, 06:39:07 PM »
dI=VdT/L
Perfect explanation then of what the Watts-Up meter is showing and I assume why cutoff is occurring.
« Reply #12 on: September 06, 2007, 06:51:47 PM »
I do try... the material sat point varies with temp too so you can expect variance with material batch (impurities), air temp, length and speed of ride, weight of the rider, and grade.
Dan
« Last Edit: September 06, 2007, 07:11:17 PM by cadstarsucks »
