Author Topic: Disabling regen mode on OLD regen controller  (Read 25626 times)
Offline caradec
« on: September 23, 2009, 12:55:50 PM »
Hi everybody,
I have a regen braking controller (in fact 2 ones, 36V + 48V, not the magic version but a 2 years old model), that I had brushed aside because I found it useless  >:( : throttle hard to balance, no way to use pedals only, braking far too strong. But now, since my standard controller doesn't work anymore, I have connected my trike 16" hub motor with this regen controller.
Of course, its defects are still present, and even more heavy, due to the small wheel size : as soon as I release the throttle (eg to change gears), the bike stops very brutally, and often the tire slips.
So I really need to deactivate the braking effect, ie the regen function, and that's where I need some help : do you think it is possible, and how can I manage ?
Thank you.
Offline robertozm
Re: Disabling regen mode on OLD regen controller
« Reply #1 on: September 23, 2009, 07:34:16 PM »
Hi everybody,
Thank you.
Hi Caradec:
If you have the Bac0200 model, yes you can disable the regen function just adding a switch that shorts the small blue cables.  see wiring diagram
http://www.goldenmotor.com/e-Bike-DIY/BLDC%20Regen%20Controller%20Wiring%20Diagram%200807.pdf
I used to use it even while in motion.  So if you need to brake hard you close the switch.  I have read about someone how even have another throttle for variable regen function, so the more throttle the more it regens.  But I don't know how to do this... sorry
Offline caradec
« Reply #2 on: September 24, 2009, 10:26:06 AM »
Hi Robertozm,
Thank you for your reply. Unfortunately, my controller has no blue wire. I guess it is an older version.
Maybe the regen can be disabled inside the box, by cutting or shorting something, even if it is definitive ? Does anybody know ?
Offline caradec
« Reply #3 on: September 25, 2009, 04:36:18 PM »
Here is a picture of my controller. Do you see a wire that can be shorted in order to deactivate the regen ?
http://www.hiboox.fr/go/images/sport/controleur,62f8037d3724a4fcf11c86d631cbd99c.jpg.html
« Last Edit: September 25, 2009, 08:54:07 PM by Bikemad »
