Author Topic: Golden Motor Solar Chargers (36V/48V 80W)  (Read 10399 times)
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
« on: June 24, 2009, 08:50:06 AM »
GoldenMotor portable and foldable Solar Charger available in 36V and 48V (80w output). The weight is 12kgs, dimensions: 67x53x8cm after folding.
You simply plug and the charging will start! You can fold the two solar panels and carry it like a suit case, easily place it into your car boot.
« Last Edit: June 24, 2009, 09:50:26 AM by Yao Yuan »
Offline pieroh
Re: Golden Motor Solar Chargers (36V/48V 80W)
« Reply #1 on: June 25, 2009, 12:40:18 PM »
I am riding my bike with your mini motor 250W kit for one month now and although I had to change rim and spokes I am very satisfied with the performance. I use Bosch 36V Li-Ion Battery packs as power source.
Do you sell your solar charger without solar modules too? Is this a Maximum Power Point- Solar Charger?
What is the voltage input range of this charger?
regards
Peter
Offline muzza.au
« Reply #2 on: June 25, 2009, 08:05:57 PM »
I'd say the solar cell is the charger. It simply supplies the voltage the battery needs and the BMS in the battery does the rest.
Muzza
Offline Philip Lynott
« Reply #3 on: June 26, 2009, 07:39:10 AM »
How long does it take to charge a 36V 16aH battery with this?
I would imagine it takes about a million years if ever - especially in Ireland.
Offline pieroh
« Reply #4 on: June 26, 2009, 12:35:35 PM »
Hi Phil,
not at all!!
I am using a Golden 250W Minimotor in a frontwheel. Distance to work ist 28km and I need ~ 150Wh from my two 2Ah Bosch fat battery packs. Assuming that you use your bike from March to Oktober you will get a solar radiation of ~ 3kWh/m²d in Dublin.
3kWh/m²d : 1000W/m² STC conditions = 3h/d of the peak power from a solar modul.
150Wh/d : 3h/d = 50W, losses of 15% --> solar module size = ~ 57Wp or bigger
A 60 to 80Wp solar module will deliver enough energy to charge the battery during day time.
I hope Golden Motor is going to sell their solar charge controller seperately, that would be a very nice option!
Offline TheKid
« Reply #5 on: June 29, 2009, 03:16:45 AM »
What's the price, and when will it be available?
« Reply #6 on: June 30, 2009, 07:24:03 AM »
Pieroh,
I have studied solar PV panels have owned some - I don't think these would be too usefull in Ireland, but let me know how you get on if you buy some any way,
Thanks,
Phil
