Author Topic: Single Wheel EV !!! buy Golden Motor  (Read 5916 times)
Offline Who42
  • ELECTRIC BIKE NUT
    • PLUG IN CARS & BIKES
« on: October 01, 2011, 08:34:20 AM »
Innovative Electric Unicycle -- Single Wheel EV !!!   :o
See Video Link:
http://www.goldenmotor.com/magicpie/SolowheelPlay.html
The Solowheel is the latest advancement in electric vehicles: an electric unicycle with gyro-sensors to help the rider maintain balance. Steer with your feet, and control your speed simply by leaning. Lean forward to speed up; lean backward to slow down or stop.
Externally, the Solowheel consists of a wheel and two foot platforms. Internally, the gyro-sensor inside the Solowheel detects angle changes to maintain balance. The Solowheel uses a three-axis accelerometer which senses falling acceleration caused by gravity. The motor is controlled, based on the signal from the accelerometer, to keep the vehicle balanced in the forward-and-backward dimension. The left-and-right dimension is controlled by the user's feet, in a manner similar to steering the front wheel of a bicycle. Because it's much easier to turn your feet than it is to turn your hips due to the smaller mass of your feet, it makes the Solowheel much easier to learn than a sitting unicycle.
One-hundred percent battery operated; leaning controls your speed. Lean forward to go forward and backwards when you want to slow down. The highly efficient lithium ion battery recaptures energy when going downhill or slowing down. You can ride at speeds up to ten miles per hour for about twenty minutes and fully recharge the battery in two hours.
In the past few years, electric bicycles, or e-bikes have become very popular. They are a green alternative to cars, save you time waiting in traffic, and can be ridden almost anywhere. The Solowheel can be used in much the same way with a few key advantages. The Solowheel is one-hundred percent portable and weighs only twenty-five pounds. This allows you to carry your wheel with you: into a store, on an elevator, into work, to the library, onto a bus or train, or into your classroom. It eliminates chaining your e-bike up to a bike rack along with others where it may get damaged or even stolen.
The Solowheel is trend setting, and while it follows others in its commitment to the environment by being green and earth-friendly, the Solowheel offers a more interesting alternative among the usual forms of electronic transportation.
ELECTRIC BIKE NUT
Offline Who42
  • ELECTRIC BIKE NUT
Re: Single Wheel EV !!! buy Golden Motor
« Reply #1 on: October 01, 2011, 08:35:38 AM »
How Much is it and when can I get one ??  and what are the specifications ?? ;D
ELECTRIC BIKE NUT
