Author Topic: tire dimensions  (Read 23008 times)
Offline caradec
tire dimensions
« on: September 20, 2009, 10:40:09 AM »
Hello, I have received a 16" cast wheel motor, but since it has no indication on it, I don't know what are the dimensions of the needed tire. 16" of course, but which width ? I tried a 16 x 2.125 tire, too thin.
Here is the drawing : http://www.goldenmotor.com/hubmotors/MW16B%20Drawing.pdf
Does anybody know ? Thank you.
TRK
  • Guest
Re: tire dimensions
« Reply #1 on: September 20, 2009, 02:33:27 PM »
According to the drawing the diameter of the wheel is 321 mm, closest to that seems to be 16 x 1 3/4 with 317 mm.  See also: Measuring Bicycle Rim Sizes.
Re: tire dimensions
« Reply #2 on: September 20, 2009, 05:44:12 PM »
It's this measurement that is causing the problem:
It probably needs a wider motorcycle type tyre.
« Last Edit: June 30, 2017, 05:23:31 PM by Bikemad »
TRK
  • Guest
Re: tire dimensions
« Reply #3 on: September 20, 2009, 06:25:44 PM »
I guess you're right, it already seemed weird to use such an unusual size, and caradec had already tried 16 x 2.125 which looked to be the widest bicycle tire in that size (ETRTO 57-305).
Offline caradec
Re: tire dimensions
« Reply #4 on: September 21, 2009, 08:27:45 AM »
For the moment, I have mounted the 2.125 - 16 tire with high inflation, and it finally seems to fit, despite it is a bit thin.
After a road test, I'll tell you. Thank you everybody.
